1993 Jeep Laredo
DRAY3108
Shakes or Wobbles problem
1993 Jeep Laredo 6 cyl Four Wheel Drive Automatic
I get a serious uncontrollable shake in the steering above 40 kph. if I hit a bump or new road surface. What could cause this? '93 Jeep Grand Cherokee 4.0
Mar 1, 2010 at 8:37 AM
BEEF99
  • 152 POSTS
This is classic and what you are describing is called the "Death Wobble" in the Jeep community. I cannot tell you what is wrong but I can tell you what causes it and where to look as there are a few different possibilities and even if you described it to me in more detail would not help.
Check the following:
Control arm bushings, worn tie rods, worn ball joints, worn wheel bearings, and any other steering components or bushings.
Jeeps are known for their Death Wobble and it is due to worn or broken parts in the steering linkeage because of their design. Do not listen to people who tell you that it is just your steering dampener as it could be bad but is not the cause of your problems and is only a bandaid fix.
Mar 4, 2010 at 12:00 AM
BEEF99
  • 152 POSTS
Also, make sure that you have not damaged any other components on your vehicle such as rims or tires and etc, even though this is probably not the root cause to your issue, it is worth checking.
Mar 4, 2010 at 12:01 AM
