1993 Jeep Laredo
113,000 MILES • 6 CYL • 4WD • AUTOMATIC
SMALLPINT
i have replaced the distrutor, ignition coil, spark plugs and throttle position sensor and still has a hard start problem. i turn the key to on wait then start and takes a few trys before start. now the jeep overheats. i replaced the twice and change the thermostat. im stuck here
Jul 2, 2009 at 3:36 AM
  • 110,251 POSTS
Three things. First, check fuel pump pressure and drop off. Here is a how to:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Next, make sure the catylatic converter isn't plugging. If all checkes out ok, check engine compression to make sure it doesn't have a bad head gasket.
Let me know what you find.
Aug 26, 2009 at 1:40 AM
