why does white smoke come out from exhaust when car is idle?
Feb 20, 2008 at 9:42 AM
M8TRIX01
MEMBER
you could have a blown head gasket. Does your temp gauge flucuate up or down? Does your exhaust smell different than your used to.
Feb 20, 2008 at 9:49 AM
DEMATTHEWS
MEMBER
[quote:236df2ecd1="dematthews"]1992 Jeep Laredo 6 cyl Four Wheel Drive Automatic 150000 miles
why does white smoke come out from exhaust when car is idle?[/quote:236df2ecd1]
yes it smells different but my temp gauge does not flucuate
Feb 20, 2008 at 12:44 PM
M8TRIX01
MEMBER
you most likely have a blown headgasket there is a couple of things to check. Check your oil and make sure it has no moister in it. It will look white. Next start your truck cold with the radiator cap off make sure it is full of fluid before you start it. If it boils out the fluid then it is defanatly a head gasket but if it doesnt it may just be a small leak and not big enough to push out the coolant. The next step would be to pull your spark plugs and check to see if any of them are white or orange looking. If you see this you have a blown head gasket.
