1992 Jeep Laredo What do you think?
209,025 MILES • 6 CYL • 2WD • AUTOMATIC
REXP
I got a quick question that maybe you guys might know right off... Vehicle was working perfectly yesterday... when I started it this morning and headed down the road I had no blinkers, no radio, no ac, and no windshield wipers. I checked the fuses but no burnt fuses under the dash. I personally didnt think I would find any, usually that many items going out is not fuse related unless the main battery fuse goes and then the car wont start at all. I have a feeling its the ignition switch located on the steering wheel, as this happened once before years ago but at that time the key mechanism failed too. So not sure. What do you think?
Jul 30, 2008 at 1:01 AM
2CARPRO JACK
  • 11,533 POSTS
Very possible.Use atest light to see if the fuses are getting power on one side, that should tell you if the switch is feeding them
Jul 31, 2008 at 12:53 AM
