1990 Jeep Laredo fuel pump
1990 JEEP GRAND CHEROKEE LAREDO
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
EDGESR
Last year the car would sometimes crank and run and other times would crank and stop as soon as the key switch returned to the run position from the start position. Finally it stopped cranking at all. Did much checking of electrical, replacing the switch on the lower steering column, checked relays and interchanged them. Checked the connector at the fuel pump but could not get a reading. Finally ran a jumper wire to the fuel pump but the pump wouldn't run. Replaced the pump and car started right up and ran great. Now the problem is beginning again. Sometimes it will crank right away and run fine. Other times it will crank and cut off as soon as switch returns to run, but after 10 to 15 tries it will finally continue to run. Any help would be greatly appreciated.
Nov 1, 2009 at 1:23 AM
SERVICE WRITER
  • 9,123 POSTS
Check the fuel pressure first.
The fuel filter should always be changed with the pump. IF it wasn't, it may have cause the pump to go bad. I have seen many aftermarket fuel pumps that are not reliable.
Nov 2, 2009 at 10:17 AM
