1990 Jeep Laredo front end shakes
STEPH90
Shakes or Wobbles problem
1990 Jeep Laredo 6 cyl Four Wheel Drive Automatic
sometimes when i get to about 45mph or higher it shakes the whole front end of my jeep. it seems like if i ease into 45 it does it worse feels like it dont do it as much if i push it. what could it be? i hvae 3inch lift and 32 11 50s on it now didnt do it until i put lift on
Feb 13, 2010 at 12:54 PM
MULDOON
  • 79 POSTS
Check the front rotors they may be warped, Declan.
Feb 13, 2010 at 1:22 PM
BEEF99
  • 152 POSTS
Unless you pay on here you will not get any advice and the advice on here is below average when it comes to Jeeps.
What you need to check are not your brake rotors. This is a typical problem for Cherokees and Wranglers. You need to check for any loose or worn parts in your steering such as tie rods, bearings, all bushings especially your control arm bushings. Any loose or worn parts cause the "death wobble" in the front end of these jeeps and it will seem like the whole front end will fall off at any second. Also, if your steering dampener is leaking and you have worn parts...it will amplify the problem.
Feb 17, 2010 at 7:11 AM
MULDOON
  • 79 POSTS
My experience was when I braked at around 50mph I got the death wobble, I had put on Chinese rotars and when I turned the origonal rotars and put them back on I solved the problem, its just my opionion, ciao Declan.
Feb 17, 2010 at 12:19 PM
BEEF99
  • 152 POSTS
If people are going to reply, please take the time to read the question completly as he did not mention pressing the brakes to get a shake.
Feb 17, 2010 at 12:26 PM
MULDOON
  • 79 POSTS
You are correct, Declan.
Feb 17, 2010 at 12:32 PM
KYLE_USMC
beef is quite right. you need to check the bearings and steering. also. something he didnt mention but can come into affect is your tire balance. however, since it didnt do the wobble before the lift then it is most likely not the cause but it could be part of it
Feb 18, 2010 at 4:24 PM
