If what you are describing is the "Death Wobble" where your front end shakes and wobbles so bad that it feel like something major is loose, then you have to check your complete front end for any worn parts such as tie rod ends, ball joints, worn contol arm bushings (these are the common problems), and check the rest of the bushings up front too just in case. Also, check your wheel bearings. Many guys will tell you to replace the steering shock /stabilizer but this is only a bandaid fix and although it will may make your death wobble go away, it will not fix it. Hope this helps.
Nov 29, 2009 at 2:19 AM
