1988 Jeep Laredo Backup Lights not working
225,000 MILES • 6 CYL • 4WD • MANUAL
PYROLATER
Where does the power come from for the back up lights?
I've got the wire traced back wards form the light to under the dash but I don't know where they are supposed to be getting power from.
The fuse panel has a fuse marked Turn BU I had assumed it was supposed to be back up but I don't think so any more. Seems like the back up lights would flash with the blinker if they were working.
I did find one drawing that shows the back up lights going through a the fuse marked trans and then through the fuse marked gauges. ???
Yes I have checked the lamps and the fuses. the switch on the transmission is good too.
Sep 14, 2010 at 3:41 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1998_jeep_cherokee_laredo_back_up_light_wire_diagram_1.jpg
First of all thank you so much for your donation.You need to check and see if you have you have power to both side's of the fuse number 6 in the inside fuse box on the passenger side.Also how did you check the back up switch?Do you have a multimeter?
Sep 14, 2010 at 5:16 AM
PYROLATER
Cool. I'll put that some place I won't lose it and hopefully I won't need it.
Thanks
Sep 15, 2010 at 6:48 AM
