1982 Jeep J10 running issues
250,000 MILES • V8 • 4WD • AUTOMATIC
CODYJENSEN
i have a 82 j 10 jeep it ran fine when i lived at 4000 ft above sea level now that i live at 600 ft it wont start not sure if it need to get a tune up or jets change in the carb. or timing thats all i can think it can be
Sep 26, 2010 at 12:52 PM
CJ MEDEVAC
  • 11,000 POSTS
Click on me...check me out, written over 500 posts (this new site revamp does not show it anymore)....I'm having a hard time navigating the new site too!.......please answer those questions.
I try do answer all of the CJ guys...CJs seldom have problems, so I came over here to assist you fellers.
I know you have a 304----I can still maybe help you, CJs have that too.
What I send may help----I would have to see what I can do about finding your 304 "necessary vacuum lines" should yours be in Helter-Skelter......and you can/or not do without the extra crap to pass emissions checks.....They check you there?
I will help all I am possible of.....Just see the link....TUNING towards the end is basically the same procedure you will do to yours, 'cept the pics are not for your 304
Jetting will probably be irrelevant, unless you have an aftermarket carb......Its the idle circuit that is probably your issue now!
Please return with something for me to do----CJs ain't coming in fast enough!
https://www.2carpros.com/questions/jeep-cj7-1985-jeep-cj7-stalls-when-hot
Waiting on you
The Medic
Nov 27, 2010 at 5:07 PM
