2007 Jeep Grand Cherokee Passenger side Floor Wet
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
LSTAR
How can you access the plugged condensed water drain line for a 2007 JGC?
Oct 30, 2010 at 8:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if you are referring to the drain to let out the excess water from the AC. It should be at the passenger side of the car. You should see the drain for the AC found alongside the pipes, may have to lift vehicle to access it good.
Oct 30, 2010 at 2:37 PM
LSTAR
Thank you for your help. I saw where the earlier model JGCs had no dratn tube but drained into a tubular memebr in the chassis and it had to be accessed from inside below the carpet. I didn't know if the "07 model was the same.
Oct 31, 2010 at 12:16 AM
