2006 Jeep Grand Cherokee Starting
10,500 MILES • V8 • 4WD • AUTOMATIC
XBAGGERE
My Grand Cherokee does not start properly.
At times , when I turn the key, it just clicks.
After several times , turning the key. it cranks over and starts up.The battery is new and the terminals are secured. Could the starter be going bad or could it be something else?
Regards,
Ed
Oct 14, 2010 at 2:12 AM
JDL
  • 16,098 POSTS
You have to do testing when the problem is ongoing. I'd probably check circuits at the starter relay, first. Some of the national brand autostores will test the starter for you. If you want to take it off and take it to them. Intermittent issues can be a pain?
Oct 19, 2018 at 4:43 AM
