2000 Jeep Grand Cherokee
11,000 MILES • V8 • 4WD • AUTOMATIC
BARNESCODY
Hello I have a 2000 jeep grand Cherokee and when I start it it turns over for 3 seconds then dies but when I start it and give it gas it will stay on until I remove my foot from the accelerator then die so when I start it and put it in reverse or drive before it dies it will stay on but die a couple blocks away unless I warm it up by leaving it in park while I give it gas for about 3to 5 min then turn off and on again and quickly put it In reverse I'm confused because there are no check engine lights coming on please help thanks
Oct 14, 2010 at 4:14 AM
WRENCHTECH
  • 20,760 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Oct 14, 2010 at 4:23 AM
