1998 Jeep Grand Cherokee stalls
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
MMARGAR
My car starts fine When the engine is cold but as i'm coming to a stop it stalls, but once it warms up it runs good, the problem happens only when the engine is cold. I replaced the Idle Air temp. control motor, the temp. control sensor, I also cleaned the throttle port, i replaced the throttle port sensor too, after all this I still have the same problem, do you have any ideas?
Oct 23, 2010 at 10:42 AM
  • 75,988 POSTS
Could be the TCC solenoid, EGR valve and throttle position sensor
Oct 23, 2010 at 12:07 PM
