1996 Jeep Grand Cherokee Replaced Transmission Filter. Prob
1996 JEEP GRAND CHEROKEE
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
JQUICK
I just replaced the filter in the transmission. After the replacement, it drives fine untill it warms-up. when it is warm the transmission does not shift properly. it shifts from first gear to second fine then it sticks in second gear. If I let off the gas peddle it will shift into second gear. Then it shifts the remaning gears fine. Is there a o-ring that goes on before the filter. Or is there a nother issue? By the way, the transmission worked fine before i replaced the filter.
Oct 5, 2010 at 2:39 AM
WRENCHTECH
  • 20,761 POSTS
Your big trigger here was changing the fluid on a car with 180K. The damage was already done but changing the fluid brought it to the surface. You going to need a trans rebuild.
Oct 5, 2010 at 3:20 AM
JQUICK
I was already told that. thought I would ask around. Thanks for your help. Joe
Oct 5, 2010 at 3:23 AM
