I just replaced the filter in the transmission. After the replacement, it drives fine untill it warms-up. when it is warm the transmission does not shift properly. it shifts from first gear to second fine then it sticks in second gear. If I let off the gas peddle it will shift into second gear. Then it shifts the remaning gears fine. Is there a o-ring that goes on before the filter. Or is there a nother issue? By the way, the transmission worked fine before i replaced the filter.
Oct 5, 2010 at 2:39 AM
