Fuse problem?
13,000 MILES • 4.0L • 6 CYL • 4WD
RON DOWLER
When I put the fuse in that works my gauges my fuel pump stops working and as soon as I take it back out it starts right back up. I know that it's the fuel pump because I sprayed a little either in the intake and it fired up.
Sep 26, 2022 at 7:00 PM
RON DOWLER
Problem solved!
When I put the fuse in that works the instrument gauges the fuel pump quit working, so I ran another 12-volt wire to the ignition wire and that solved everything!
Sep 28, 2022 at 1:06 AM
  • 55,731 POSTS
Sorry we couldn't get to you in time. Excellent job fixing the problem and sharing with our readers. Please use 2CarPros anytime we are here to help.
Sep 28, 2022 at 8:50 AM
