jeep dies while driving or at anytime
202,000 MILES
SERGIOGM1963
my jeep dies while driving most of the time dies after it gets hot like after 30 minutes driving after that the car starts to die more often sometimes starts right back and some times takes like 5 minutes to start but always starts up again it has been doing this like for 3 months
Oct 16, 2013 at 8:15 AM
JDL
  • 16,098 POSTS
How long since a tune-up? Does it stall going down the highway or only at idle? Can you check for applicable trouble codes? You can try cycling the ignition switch, on--off, on--off, on, then the mil on the dash starts flashing, you count the flashes to get the codes. Your looking for two digit codes. I'll have to double check that procedure. Get back to you.
Oct 16, 2013 at 9:01 AM
