Jeep dies out while running and idle.
111,000 MILES • 4.7L • V8 • AWD • AUTOMATIC
FEARLESSJIMBEAM
dies out while driving and while at idle. It is like the key was just turned off but still in ACC. I lose my gauges but still have power to the whole Jeep. It will turn over but will not start the warning lights on the dash are on including the key light. When I turn the key off the hazardous flash twice. So if I let it sit for a few minutes it will start right back up. When it is down I have hooked it to a scanner and it says no key found turn key on. They key is in fact in the on position when trying to run the test. After the system starts to work again there is no warning lights on the dash anymore so the scanner doesn't find any problems. The Jeep starts and runs fine until it happens again. The battery is brand new I replaced it with a yellow top optima. The volts are good from the alternator they are steady 13.95 to 14.10. I have an older G4 Cliffrod alarm system in it. The people I have talked to said it's the alarm system causing it to shut down. Thinking that is been stolen or something. I am not so sure that it's the alarm that's problem so please if anyone has any ideas. I am open to try just about whatever it takes to get this thing running.
Mar 27, 2017 at 2:18 PM
HMAC300
  • 48,601 POSTS
this is a security system issue have a mechanic scan with his scanner to see what the problem is it may be a bad transponder or security unit.
Mar 27, 2017 at 11:25 PM
FEARLESSJIMBEAM
You think it'll still find the problem? I've hooked it up after it is working again and it doesn't come back with anything. Do I need to use a better scanner or setting in the scanner?
Mar 29, 2017 at 2:16 AM
HMAC300
  • 48,601 POSTS
you need a professional scanner to read security as wellas other issues code readers that are under a couple thousand dollars won't read that
Mar 29, 2017 at 2:29 AM
