Transmission will not shift into reverse
10,000 MILES • 2.0L
BONITA 26
Transmission won't go into reverse because cable snapped broke the gears are working it snapped just under gear stick.
May 5, 2021 at 2:00 AM
If the cable snapped then you will have to replace it. I attached the info from the manual on how to replace this from the manual. Please run through this material and let us know if you have other questions. Thanks
May 5, 2021 at 9:21 AM
