1988 Jeep Comanche oil circulation
140,000 MILES • 4 CYL • 4WD • MANUAL
BRYCESON4
The truck is pushing out oil through the top of the engine, especially through the "new" valve pan cover gaskets. we changed the gasket because of this problem. It is like the oil is getting stuck in the top of the engine and not circulating back down. Please tell me what could be going on, if you can.
Nov 26, 2008 at 9:26 AM
RMASER
  • 11 POSTS
how dirty was this engine when you changed the vavle cover gasket,the oil on top of the head just flows thru a return hole back to the pan,it has to be pluged with guck
Dec 1, 2008 at 12:57 PM
