1988 Jeep Comanche jeep commanche
1988 JEEP COMANCHE
80,141 MILES • 6 CYL • 2WD • MANUAL
SHANEROGERS187
im wondering if i can use cherokee parts for this vehicle. i need to replace ignigtion switch or maybe whole stearing colum. i'm also having problem figuring out it runs real ruff, that it almost shakes the whole jeep, but then sometimes it doesn't sounds like a whooshing sound when you push in brakes, could it be the master cylinder or any suggestions??
Sep 27, 2009 at 11:18 AM
JEEPFAN
  • 135 POSTS
yes most parts will interchange as a matter of fact wagoneer parts will also work as far as running rough have you checked the plugs and wires? like i said alot of the parts will work some will not im not sure about the column
Sep 27, 2009 at 11:46 PM
SHANEROGERS187
tried the plugs an wires its wierd when i push on the brakes it acts like it wants to cut off, an there is is a air flow like sound coming when i push brakes, thanks for responding buddy
Sep 29, 2009 at 6:59 PM
JEEPFAN
  • 135 POSTS
check the vacun hoses for leaks as a vacum leak will cause rough engine and if you hear a hissing sound when you press the brakes or the pedal travels father than usual your brake booster may be going out
Sep 29, 2009 at 7:09 PM
SHANEROGERS187
if it was the booster would it make the engine cut off? you close to akron oh ?? just wondering you may be looking for a side job lol !
Sep 29, 2009 at 7:29 PM
JEEPFAN
  • 135 POSTS
i dont think it would cause it to cut off but if its loosing enough vacum it could be possible.
and no im in tx. anyway i hope maybe ive helped let me know what you get figured out
Sep 29, 2009 at 8:57 PM
