1987 Jeep Comanche ENGINE
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOEGALLE
In a 1986 Jeep Comanche which has a 6cyl.2.8L engine with auto trans. Would I be able to put a 6cyl 4.0L in this Jeep ?
Dec 30, 2009 at 4:32 AM
HMAC300
  • 48,601 POSTS
you probably could but it would be a ton of work. If memory serves me right the 2.8 was a GMengine and if it was you may be able to put a 3.4L engine from a camaro in it. But make sure to measure everything correctly. You woud also have to get your torque converter balanced for the 3.4 or maybe a camaro one would work. that would be the easiest if you want to upgrade..
Mar 21, 2010 at 11:00 AM
