Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Comanche
Warning Lights
Low Coolant Light
1986 Jeep Comanche coolant light
1986 JEEP COMANCHE
128,000 MILES • 6 CYL • 4WD • MANUAL
MSNOW863
MEMBER
1 POST
how do i know if my light is working,how do i check the bulb and the plug the bulb goes in
Oct 17, 2010 at 2:14 PM
Experienced Mechanic
To check a bulb, remove it and run a continunity test on it. If you have continunity, it is good.
Are you concerned that the light should be coming on but isn't?
Oct 18, 2010 at 6:36 AM
WRENCHTECH
Most all of the bulbs should come on for a bulb test for few seconds every time the key is turned on.
Oct 18, 2010 at 6:40 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
