1986 Jeep Comanche coolant light
128,000 MILES • 6 CYL • 4WD • MANUAL
MSNOW863
how do i know if my light is working,how do i check the bulb and the plug the bulb goes in
Oct 17, 2010 at 2:14 PM
  • 110,251 POSTS
To check a bulb, remove it and run a continunity test on it. If you have continunity, it is good.
Are you concerned that the light should be coming on but isn't?
Oct 18, 2010 at 6:36 AM
WRENCHTECH
  • 20,758 POSTS
Most all of the bulbs should come on for a bulb test for few seconds every time the key is turned on.
Oct 18, 2010 at 6:40 AM
