1985 Jeep CJ7 Headlights
1985 JEEP CJ7
TKOPP
Electrical problem
1985 Jeep CJ7 V8 Four Wheel Drive Manual
Guys,
I have a 1985 CJ7 that i restored
I installed new Halogen headlights
everything is new, Wiring Harness, etc.
The problem is that about 10 to 15 minutes after
i turn the headlights on, they begin to Flicker
then eventually go out
I have a new Battery, etc.
What is the problem
Thanks,
Ted
Sep 8, 2008 at 8:07 AM
KHLOW2008
  • 41,814 POSTS
Hi Ted,
Thank you for the donation.
Does high beam works?
Possible causes.
1. Bad ground.
2. Faulty switch.
3. Bad wire connections. Check for overheated connectors.
4. Blown fuse.
5. Blown bulbs.
Sep 9, 2008 at 1:32 AM
