1985 Jeep CJ7 battery keeps dying
1985 JEEP CJ7
111,000 MILES • 6 CYL • 4WD • MANUAL
MAR1565
i have a 1985 jeep cj7 and have had to replace the battery over 10 times in 10 years...I have had numerous auto specialist?? check it out and say they can't figure it out?? I have everything new starter, celinoid, alternator, wires, etc, but if i don't drive it for a week or so the battery is dead dead (no good). HELP!
Oct 29, 2010 at 11:15 AM
WRENCHTECH
  • 20,761 POSTS
There is a procedure for finding a battery draw like that.
You will need a digital ammeter and a jumper wire with clips on the ends to do this.
First rig any door switches so you can have a door open without triggering the interior lights and unplug the hood light. Remove one battery cable and attach the meter in series between the battery cable and battery post. Take the jumper wire and also attach it the same way. Leave the jumper wire on for at least 10 minutes to expire all the automatic timers. Now remove the jumper wire and read the meter. Anything over 50ma is too much draw. The way you locate this is to start removing fuses one at a time until the meter drops to normal level. This will be the circuit with something staying on. Determine what components are part of that circuit and check them individually until the problem is isolated.
Oct 29, 2010 at 12:26 PM
