1984 Jeep CJ7 wont keep brake pressure
1984 JEEP CJ7
105,000 MILES • 4 CYL • 4WD • MANUAL
JOEQUICK
how can i get my jeep to keep brake pressure i have tried just about everything new lines brakes are good no air inline. just replased master sylender still nothing.
Jan 19, 2010 at 6:15 AM
2CARPRO JACK
  • 11,533 POSTS
You may have astuck caliper or nbad wheel cylinders.Try using a rag wrapped around the rubber brake hose at the front wheels, one at a time use pliers and the rag to pinch off the hose, if the caliper is bad the pedal will hold. Also try this at th erear brake hose to eliminate the rears as the problem
Jan 22, 2010 at 10:17 AM
