1984 Jeep CJ7 Vibrating when in gear
156,000 MILES • 6 CYL • 4WD • MANUAL
ROUTER
My Jeep is developing an issue, when in gear it has begun vibrating, I mash the clutch and the vibration stops. It has been getting worse and now I am worried about continuing to drive it. Thanks for the help in advance.
Dec 1, 2008 at 3:53 AM
RACEFAN966
  • 5,029 POSTS
Ok sounds like a clutch or a throw out bearing retainer problem. If I am understanding right when the clutch is engaged you have a vibration and when you step on the clutch pedal and disengage the clutch the vibration goes away. Is that correct?
Dec 1, 2008 at 2:29 PM
ROUTER
Yes, that is correct.
Dec 2, 2008 at 10:18 AM
RACEFAN966
  • 5,029 POSTS
Ok then it could any one of these problems clutch pilot bearing throwout bearing retainer on the end of transmission or the front bearing. Unfortunatly you won't know which it is until you take it apart and check it all out. Don't forget to turn the flywheel if you need to replace the clutch, make sure they have a turntable type and cut it with a stone not a brake lathe.
Dec 3, 2008 at 1:43 AM
