1984 Jeep CJ7 thermostat
1984 JEEP CJ7
CJ84
Engine Cooling problem
1984 Jeep CJ7 6 cyl Four Wheel Drive Manual
what is the correct direction to install a thermostat in my 84 cj7?
Sep 18, 2010 at 10:14 AM
MERLIN2021
  • 17,250 POSTS
Let the engine cool off, then drain it down about a gallon, there is a draicok on the bottom of the radiator, then follow the upper radiator hose to the engine, there you will find the thermostat at the end of the hose, unbolt the two bolts. leave the hose attached to the housing. Scrape old gasket from both mating surfaces, install new thermostat, spring towards the engine. install the gasket, snug the housing bolts! Not to tight and bring the housing down evenly. refill the coolant and that's it!
Sep 18, 2010 at 10:49 AM
