1984 Jeep CJ7 oil pressure
1984 JEEP CJ7
138,000 MILES • 6 CYL • 4WD • MANUAL
PICKLEPANTS
oil pressure drops to zero at idle, but as a drive or rev the engine, it raises, but never getting above about 40
Jun 3, 2010 at 10:30 AM
CJ MEDEVAC
  • 11,004 POSTS
See my profile,
Install a Mechanical Gauge, You can temporary it on the engine (reg 0-100 gauge) Or just purchase a Parts store model (has little tube) and run it under the hood---thru your window. If it works out, that engine is fine (bad gauge or sender) Install it permanently thru the firewall.
Let me know what you got, maybe Mr. Engine is OK, 258 is a tuff puppy!
While you are here check out "1985 Jeep CJ 7 Stalls when hot" (several down from you)---One of my masterpieces!
Love, Turddog
Jun 3, 2010 at 4:46 PM
