1984 Jeep CJ7 ingnition system
MVLOET13
  • 1984 JEEP CJ7
Electrical problem
1984 Jeep CJ7 6 cyl Four Wheel Drive Automatic
jeep wont turn over, battery is good and soleniod is good. Any other ideas?
Sunday, June 8th, 2008 AT 12:21 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Do you recieve 12V to the ignition coil? If not then there is a problem with the ignition control module or the ignition switch. If you do then most likely the ignition coil is bad. Does it feel hot when the ignition is on? Check the primary and secondary on the igntion coil to ensure it is dead.
Tuesday, June 24th, 2008 AT 1:05 AM
