1983 Jeep CJ7 engine stalling
200,000 MILES • V8 • 4WD • MANUAL
WERBROWNS
I installed a Chevy 1994 5.7L engine in to my jeep. When hot the jeep spudders really bad and sometimes dies. If I let the jeep set for about 30 minutes or more, it will restart. However, it more common when going up an incline I get a lose of power and feels like it is starving for fuel.
I was wondering if I was experiencing vapor lock since it does restart after it cools off. However, it is a TBI. Since this is a transplant, I did install an electric fuel pump from Napa Auto. However, I did not install a fuel regulator. Where is the regulator suppport to go and can this cause the problem?
Thank you for any input you can provide.
Rob
Jul 5, 2008 at 5:32 PM
  • 75,988 POSTS
Check the fuel pressure and also for restriction in the exhaust system-
Jul 5, 2008 at 5:35 PM
WERBROWNS
I noticed that the catalytic converter is bluish purple in color too. I've read other forums that the return line on a non-tbi is to small when converting to a tbi system. Is this true? I'll looking at buying a fuel pressure guage so I can check the psi at the tbi.
Is the pressure regulator built in to the tbi or is it external?
Jul 6, 2008 at 7:32 AM
  • 75,988 POSTS
Its in the TBI unit- Test the fuel pressure and comeback with the readings.
Jul 6, 2008 at 10:11 AM
WERBROWNS
will do. It will most likely be later this week. I have to order a guage.
Can the catalytic converter be causing any of the exhaust restriction you mentioned prior? I don't get the strong sulfer smell, but I noticed the discoloration of it.
Can a smaller return fuel line cause a back pressure?
Jul 6, 2008 at 12:16 PM
WERBROWNS
[quote:aba73cc45d="rasmataz"]Its in the TBI unit- Test the fuel pressure and comeback with the readings.[/quote:aba73cc45d]
I finally received and installed my fuel pressure gauge. When I turn the key to running position, I get 5psi. When I start the engine, I get 8psi. Sounds like my pump is a little short of the 13psi.
My current pump is a universal pump from Riebes. Doing some more research, I find that the Master E8153 pump is recommended pump for my conversion.
Jul 20, 2008 at 6:00 PM
