You mentioned cycling the ignition switch, my first thought was check the feed circuits to and from the ignition switch, when the problem is ongoing. The problem may not be those circuits at all, you have to start somewhere?
The next time it dies on you, don't recycle the switch, just leave it on. Check for primary voltage at the ignition coil, use a testlite. Primary voltage to the coil comes from ignition switch.
Tuesday, September 1st, 2009 AT 10:52 AM
