1982 Jeep CJ7 Steering Drift
90,000 MILES • 6 CYL • 4WD • MANUAL
JANTHONY
I have had steerring issues since owning this C-J. When driving it is almost impossible to hold a straight line in the road. There is no return to center with the steering wheel, if I turn left and let go, the wheel will stay left. I have had the steering box replaced and steering shaft replaced. This helped almost none. It is borderline dangerous to drive, hope someone can help.
Nov 21, 2008 at 5:23 AM
  • 31,937 POSTS
Hi there,
The self centering is part of the alignment design, so i would be checking the alignment and also for a seized or very tight ball joint or tie rod end, start here.
mark (mhpautos)
Nov 21, 2008 at 10:01 AM
