1981 Jeep CJ7
MBASSJR
  • 6 POSTS
Transmission problem
1981 Jeep CJ7 6 cyl Four Wheel Drive Manual
Was pressure washing underneath my jeep and now it rolls while its in gear like its not catching.
Jun 4, 2010 at 2:12 PM
CJ MEDEVAC
  • 11,000 POSTS
OK JEEP FELLER (like me) See my profile
Jeeps designed for water, I do not think you have hurt the tranny itself, or the transfer case.
I need a little more info, answer the following:
Rolls in gear, like not catching?....Does that mean it rolls as if its out of gear?
Did you pressure was up inside the BELLHOUSING?
(if so, maybe clutch disc got real wet and maybe oil on it too)
Will it go in gear and drive? (How does it act?)
Did you by chance, BLOW YOUR TRANSFER CASE (Linkage) SHIFTER INTO NEUTRAL? (shift back into 2 HIGH, inside your rig)
Did you maybe BLOW LINKAGE APART? (Via missing bolts/worn pivots, ETC.)
Give me some answers, willing to help alot, see "1985 Jeep CJ 7 Stalls When Hot" (14 responses, other CJ 5/7 Posts) several below yours, you will see the extent I will go!
Love, Turddog
Jun 4, 2010 at 2:44 PM
MBASSJR
  • 6 POSTS
It had a lot of mud and grease build up underneath it, between the skid plate and the transfer case. I cant shift it into any gear and it feels like its in gear but if I push it, it rolls thru the parking lot like its in neutral. I cant crank it right now because I was replacing the gas tank and its not on the jeep. I was trying to clean underneath it before I put the tank back on.
Jun 4, 2010 at 3:00 PM
CJ MEDEVAC
  • 11,000 POSTS
I am assuming you mean: The stick will not move from neutral? Stuck in a gear (won't move from it?) Did you investigate transfer case shifting ability? Pushing a little and trying to shift, does that work? Remove Shifter floor plate (takes a few minutes) See if you trhu some mud/gravel into the top of the tranny tower (where stick goes in) Presently 11:20 PM EST, I am in my garage, replacing the dimmer switch connector on my '46 Willys (typical Jeep Lights flashing on and off at night) I will be here for you for a while, Keep info coming Love, Turddog
https://images.2carpros.com/forum/automotive_pictures/411289_WILLY_ALWAYS_KEEPS__A_STRAIGHT_FACE_1.jpg
Jun 4, 2010 at 3:22 PM
MBASSJR
  • 6 POSTS
The stick will actually shift into place as it is suppose to. When I shift it into any gear it feels like it is suppose to but the Jeep itself rolls as if it is in neutral. When I push it (the jeep that is). I got the jeep from a friend and I am trying to fix it up. He told me when I got it that the 4 wheel drive was not hooked up. I dont know alot about working on vehicles. It would shift into gear and hold itself on a hill before I pressure washed it.
Jun 4, 2010 at 3:27 PM
CJ MEDEVAC
  • 11,000 POSTS
Still nothing about TRANSFER CASE SHIFTER?
In the floor beside your gearshift is a smaller shifter, It has 4 positions----2 LOW---NEUTRAL---2 HIGH (what you should "NORMALLY" be in, if all stuff is working right) ----4 HIGH....YOU SHOULD HAVE A DANA 300 TRANSFER CASE (300 pattern slips my mind)
I have the next one down in my '77, its a MODEL 20, my pattern is as I descibed to you above, with 2 LOW being nearest the rear of the Jeep----YOUR KNOB will verify YOUR PATTERN (unless its missing)....I would go across the street and look at Ron's '83...probably get shot this late!
Try shifting the transfer case, look under it for loose linkages, GET A MANUAL!---so you know what stuff is supposed to look like!
As far as no 4X4, you may be missing front driveshaft, locking hubs, broke transfer case, or transfer case linkage loose or missing---to name a few EZ ones.
YOUR TURN!
Love, Turddog
Jun 4, 2010 at 3:57 PM
MBASSJR
  • 6 POSTS
Well I guess I will have to say I dont really know what to do or look for at this point. I have two shifters. The regular 5 speed shifter and the 4 wheel drive shifter which according to Morris 4x4 center should be from front of jeep to back: 4low, neutral, 2high and 4high for my year model. I tried shifting it though and it doesnt seem to move through the gears as it should. I didnt try shifting it before today though because he told me something wasnt connected. I guess I will just have to try getting under it tomorrow when its light outside and try to come up with something. I am at the Firehouse where I work and Its pretty late. Good luck with your project. When its light out and I can come up with something I will try to reply and give you further information. Thanks for the ideas.
Michael
Jun 4, 2010 at 4:09 PM
CJ MEDEVAC
  • 11,000 POSTS
My project is done---works like it did 20 years ago when I built it from scratch.
Investigate what you are missing 4X4 wise, If you still have rear drive shaft---you more than likely need to be in "2 HIGH"
Transfer cases are sometimes hard to shift, sometimes motion with Jeep might help it or just a good hard push.
I will continue to assist you, as long as you keep replying here.....sometimes I may not respond this quickly, since I do other stuff too. BUT I WILL RESPOND!....Can make you Mechanical pics of my Jeep ('77 not '46) and of Ron's '83 (like yours) Tell me what you want a Pic of....Try to get it soon!
Am sending you a PM (private message, within 10 minutes) [see index to get it] Let me know there, if you want to see my Albums of Jeep Modifications.
Love, Turddog
Jun 4, 2010 at 4:25 PM
CJ MEDEVAC
  • 11,000 POSTS
Sorta jumped out of bed wiith a possible explanation.
If your rear end is not hooked up, or something wrong with it, YOU MIGHT BE DRIVING IN FRONT WHEEL DRIVE ONLY!
If this is the case, the only way your Jeep will move is: TRANSFER CASE IN-----4 HIGH---or----4 LOW (low would be geared really low, and not feesable for Road Speeds)
So lets say you are driving only with the front wheels, and in 4 HIGH, this would work fine until you get 'er fixed.
But lets also say that YOU-----or-----"Sparky" the Firehouse Dog, Just so happened to be out there with you....while you were messing with Mr. JEEP.
People like to touch stuff!!!! / So do those darn Fire Dogs!!!(maybe it was you!)
If for some REASON, SOMEONE UNLOCKED ONE, OR BOTH of your locking hubs (front wheels).....The front axle would just FREEWHEEL in place---------THUS JEEP WOULD ROLL FREELY!
Both should be in 4X4 position (Hubs locked in), if you are dependent on the front axle to pull your Jeep [if this be the case].
Reply, I will see it in the morning!
Love, Turddog
Jun 4, 2010 at 5:43 PM
MBASSJR
  • 6 POSTS
Jeeps transfer case was knocked out of gear. Got it fixed. New issue! Putting a new ignition switch and the old wires are "OLD". Is their somewhere I can find the wiring diagram so I can make sure the wires line up?
Jun 7, 2010 at 1:03 PM
CJ MEDEVAC
  • 11,000 POSTS
Allright CJ Guy, We will explain some stuff, I know you are new with Jeep, Be gentle and He will do you right.
Dependent on how far you want to carry this, a Chilton Manual would be your best and least expensive route...I RECOMMEND "Chilton" part # 8034 or its newer edition for CJ-5, CJ-6, CJ-7, Scrambler, Wrangler 1971-1990 Repair Manual (If newer is for CJs only, get it........My manual, bought a good while back, has good diagrams and decent descriptions and it is a LARGER BOOK! (about $30-$40)
"Haynes" Manual is very VAGUE with the steering column. I would skip it for the ignition switch problem, but some manuals offer different Pics and it may help on another problem-----I have about 12 Jeep manuals, and 15 or so for other rigs I have/had
The very best you could do is a AMC service manual for "your year" or a close-by year (my 1979 manual would even get you 98% of the way thru, with very minor changes from year to year)....This would be about a $75-$130 investment, and could be found at FYI MANUALS on the internet.....It is the Absolute Best Manual to Have....It is written for 2nd Graders, has many Real PICS and Diagrams...Many test procedures-----Most of the other manuals "Steal" from this one...This is the so-called Bible.
I can maybe talk you thru doing the actual "KEY SWITCH" or "LOCK CYLINDER"----A reference would still prepare you and Let you know the correct names of the parts "WE" would be dealing with. As long as you did not jump ahead, nothing would get broke----most people get impatient and break out the Hammer and screwdriver! (I Know some tricks)
As for wiring, there will be none associated with the cylinder itself
The turn signal swith would come into play, a little, but if its good---no need to replace it, however if its bad---NOW is the best time!-----It just plugs in near the base of the column----unless someone has "Butchered it" (those wires) It will be relatively EZ
Are you mechanical or have pals that way?
Do you have access to basic tools/pullers?
I CAN AND WILL HELP--Your help is appreciated too, for I type slow....if you comprehend well, I won't have to talk 1st Grader---things will move faster.
If you could at minimum read up on it, I will give you the REAL WORLD way to do it, and you will understand better. Sometimes books assume you understand....But once thru it with experienced help---You will be an expert!
The 2car guys sorta suggested a name change ( no likey the Dog name) So I picked CJ MEDEVAC....Better?
Did you see/read "1985 CJ 7 Stalls When Hot"?
If you will view my Walmart Stuff, you will see how SERIOUS and Time consuming I am with making a Jeep Better. (RE: PM, I sent)
Please Respond,
The Medic
Jun 7, 2010 at 2:16 PM
MBASSJR
  • 6 POSTS
Sorry! I have been getting on the computer then going outside and working on the jeep. My blackberry just doesnt have the viewing capabilities that I need. I think I got the wires right. I got the tank back on today and got it to turn over a few times but I think my issue now is that I need a new cilinoid. I have to get one tomorrow. Name is cool now. Will try to give an update when I come back to work in a few days. Thanks again.
Jun 7, 2010 at 3:19 PM
CJ MEDEVAC
  • 11,000 POSTS
When you spell "Jeep" Always use a CAPITAL "J"---otherwise it looks as if "He" is not important to you! "HE" is a pronoun expressing "STRONG"---"MANLY" TraitsNever name your Jeep a "Sissy Name" like Chevy and Dodge owners do ! THIS IS EXACTLY WHAT STUFF DOES---READINGS ON A VOLTMETER AND WHEN! HOW YOURS SHOULD BE IDENTICALLY BE HOOKED UP! ! ! Special Attention to all Mechanical Electrical Joints! Let me know if it helped you. If the "CRAP" on down doesn't help, It could be the "cable" to the starter (clean/tighten) or the solenoid itself----even the starter......Try this stuff below 1st!!! TAKE STUFF LOOSECLEANTIGHTEN WELLDO NOT JUST PASS IT OFF AS, "IT LOOKS GOOD". Do not leave off where the Battery cables connect to the Battery clamps! (not the posts) Do them too! While you are at it, Both ends of Pos cable, Both ends of NEG cable. If you still have the problem, you're probably looking at $20 to replace the SOLENOID. Follow Battery Positive cable to find it. My stuff may be OVERKILL, but at least you will know what everything IS and DOES. Like my newly made "NELSOMATIC" stuff? I am cyber stupid, and did that! Keeps me from hunt and pecking so much! Please Reply, Good or Bad. Follow POS BATT CABLE, It will end up here, at the SOLENOID, looks vary, function is the same.
https://images.2carpros.com/forum/automotive_pictures/411289_A_B_C_D_EXPLANATION_2.jpg
https://images.2carpros.com/forum/automotive_pictures/411289_A_B_C_D_17_LOCATIONS_2.jpg
"FORD TYPE" SOLENOID SYSTEM, YOUR ACCES., MAY VARY 1) POSITIVE CABLE FROM BATTERY 2) OUT TO STARTER MOTOR 3) ON MY JEEP, THIS GOES TO THE ALTERNATOR 4) THIS FEEDS MY FUSEBOX (ALL OF MY ACCESSORIES) 5) "S" WIRE IS FROM KEY, 12V ONLY WHILE YOU ARE "CRANKING" THIS WIRE ACTIVATES THE SOLENOID'S ELECTROMAGNET, WHICH IN TURN, CONNECTS---A & B INTERNALLY (ONLY THE 2 LARGE GAUGE CABLES CAN HANDLE THE AMPERAGE THE STARTER "PULLS"). WHEN THE SOLENOID IS ACTIVATED, IT THROWS 12V TO STARTER USING THE LARGE GAUGE CABLES (1) POS FROM BATT--THRU SOLENOID INTERNAL CONNECTION--(2) TO THE STARTER, WHILE KEY IS IN "CRANKING" MODE. THIS IS THE TOTAL REASON FOR A SOLENOID, BECAUSE IT WOULD NOT BE PRACTICAL, TO RUN THE HEAVY CABLES TO AND FROM YOUR KEY SWITCH. 6) "I" WIRE (OPTIONAL), FEEDS COIL "FULL 12V", ONLY WHILE "CRANKING", AFTER YOU RELEASE THE KEY, THE COIL REVERTS BACK TO REDUCED VOLTAGE (via resistance wire), SUPPLIED BY YOUR KEY IN THE "RUN" POSITION. This resistance wire, IS A RESISTOR!....Your COIL should be one stating: "FOR EXTERNAL RESISTOR ONLY" 7) "MOUNT" GROUND, UNIT MUST HAVE A GOOD GROUND (BATT. TO ENGINE, ENGINE TO FRAME, FRAME TO BODY [ALL MUST CONNECT, SOMEHOW] ) (3 & 4, ON MY JEEP) ARE FUSABLE LINKS, ALL ARE NOT MARKED, MY #3 IS, #4 IS NOT....ITS SORT OF A "WIRE" FUSE. IF THEY ARE GOOD, TUGGING ON THEM WILL BE JUST LIKE A WIRE, WHEN THEY ARE "BURNED UP", THEY WILL STRETCH OUT LIKE A RUBBER BAND.
Jun 7, 2010 at 4:06 PM
