1980 Jeep CJ7
1980 JEEP CJ7
REGGIE KEMP
Engine Mechanical problem
1980 Jeep CJ7 4 cyl Four Wheel Drive Manual
I have a 1980 Jeep CJ7 4-cylinder engine wih a Rochester 2 bbl carb. Can I use this carb on my 1983 Jeep CJ7 6-cylinder engine?
Jul 10, 2010 at 9:27 PM
CJ MEDEVAC
  • 11,004 POSTS
See my profile and other CJ 5/7 posts I have answered. I am not a paid mechanic or paid here either...Member like you (this is my hobby) I know CJs well. Keep your problems coming...I will help all I can. Will it bolt on? I am not familiar with the Rochester. We bolted a '77 1 bbl YF onto a 4-150 or 151 into a '86....Linkage needed a little modification to work....before we got in deep....we bolted it on and ran a temporary fuel line...and a wire to "hand accellerate" the Jeep, after it worked decent and no deprivation of fuel.....My friend put it on permanent. Whats wrong with your BBD?....I recommend Using a BBD...from like a '79---has no computer stepper motor....EZ to tune. Available "Rebuilt" from Autozone or Advance Auto....Reasonable. As seen below.
https://images.2carpros.com/forum/automotive_pictures/411289_111_001_1.jpg
As far as vacuum line issues or other problems you might have ........See "1985 CJ 7 Stalls When Hot" just down the list from yours---14 replies. I will help you all I can with CJ stuff---just keep replying here. I have a sweet set-up on mine (not for showing out, but for power and fuel milage) Its a Offenhauser 4 bbl intake with a Holley 390 CFM (0-8007) 4 bbl. Seen Below Respond The Medic
https://images.2carpros.com/forum/automotive_pictures/411289_100_0327_1.jpg
https://images.2carpros.com/forum/automotive_pictures/411289_100_0328_1.jpg
https://images.2carpros.com/forum/automotive_pictures/411289_regular_4_bbl_bicycle_cable_linkage_1.jpg
Jul 11, 2010 at 7:41 PM
