Transmission problem
1978 Jeep CJ7 6 cyl Four Wheel Drive Manual n/a miles
I have a 78 CJ 7 with a 3 speed tranny, the clutch wasn't disengaging so I dropped the tranny and had to replace the driven clutch plate and the pressure plate. In order to drop the tranny I had to remove the shifting assembly from the top of the tranny. But now the tranny wont shift into any gears other then reverse. The shifter moves into each gear location seemingly fine but reverse and first position make the jeep go backwards and the second and third gear location make the jeep shutter and stall. I cant see how this is possible with such a basic design?
Apr 21, 2010 at 5:03 PM
