1977 Jeep CJ7 Removal W/engine
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
TIMS JEEP
I have plans to remove 258 engine and AMC TH400 as one unit (front group off) before replacing with 4.3 V6, same transmission. I want to know how the trans seperates from the T-case? Bottom support plate appears to hold T-case in place directly behind trans so I have not removed it. Is there a slip-joint yoke that will simply seperate upon pull away or what?
Mar 29, 2008 at 6:37 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, once the t-case is unbolted from the trans, it will just slip off. There shouldnt be a mess in doing so, there is a seal betwen the two
Mar 30, 2008 at 1:00 AM
