I have plans to remove 258 engine and AMC TH400 as one unit (front group off) before replacing with 4.3 V6, same transmission. I want to know how the trans seperates from the T-case? Bottom support plate appears to hold T-case in place directly behind trans so I have not removed it. Is there a slip-joint yoke that will simply seperate upon pull away or what?
Mar 29, 2008 at 6:37 AM
