hi
Need alittle more info does the starter crank engine?
and will not fire up? or no stater operation?
Let me know
Thanks for donate
Aug 16, 2009 at 1:25 PM
VIPER1701D
MEMBER
we tested the battery and the starter and they both were fine but it wont crank or turn over
Aug 16, 2009 at 1:36 PM
DOCFIXIT
✓ASE Certified Mechanic
Maybe ignition switch put test light on solenoid terminal ie. small wire turn to start. Shlud light if no then ign. switch faulty. Automatic or manual trans? could also be neutral safety switch Or clutch switch
Aug 16, 2009 at 2:26 PM
VIPER1701D
MEMBER
i got it started again but if it wont crank again what could it be?
Aug 16, 2009 at 3:48 PM
DOCFIXIT
Ignition switch, neutral safety or clutch switch also corroded batt terminals
Aug 16, 2009 at 3:56 PM
