1979 Jeep CJ5 Ignition related
78,000 MILES • V8 • 4WD • MANUAL
BOUDREAUX-T-LAFEITE
only happened twice. When the engine was cold. About 2 miles into my early moring trip to work. It looses all fire or ignition. Just dies liken you turnn the key off. I pull over and stop. Turn the ignition off. Turn ignition back on cranks right up. No further problem for rest of trip. Could it be a solid state modulator like the gm trucks had of that era? They only gave me problems when hot tho. Thanks for any assistance. Deciated jeep owner Cajunator
Mar 19, 2009 at 4:47 AM
  • 75,988 POSTS
Next time it dies out -do below immediately to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 19, 2009 at 8:55 AM
