1978 Jeep CJ5 Vehicle Starting
RFORDVT
Engine Mechanical problem
1978 Jeep CJ5 V8 Four Wheel Drive Manual
In attempting to get a vehicle running again that had sat for approximately 2 years, after replacing the battery and the fuel, the only way to start it was to pour gas down the carb and it would cut off immediately after it ran through that gas. Figuring it was a fuel delivery I checked the fuel lines and replaced the fuel pump (mechanical). Still wouldn't start and cut off after pouring gas down the carb. Rebuild and cleaned carb, still wouldn't start cold (unless vehicle had been running withing the past hour or so). Dealt with the starting issue by pouring gas down the carb whenever I had a cold start. Now the vehicle won't start even attempting a rolling start. Is this an ignition problem (starter, battery, starter solenoid good), haven't replaced the plugs or wires?
Aug 17, 2010 at 4:31 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Does starter operate? is there spark at plugs? does choke close on carb when cold? plugs good idea to put in new ones.
Let me know
Thanks for donate
Aug 17, 2010 at 6:14 AM
RFORDVT
Starter is in good operation. Planning on replacing the plugs and recharging the battery tonight. If the plugs were bad, wouldn't I have a problem with vehicle running operation? I have only had a problem during cold starting to this point.
Aug 17, 2010 at 6:50 AM
CJ MEDEVAC
  • 11,000 POSTS
See my profile, and many other CJ 5 and CJ 7s I have answered.
I do not mean to butt in, but it sorta sounds like a Choke, maybe vacuum line issue.
Are you getting spark at the plugs during "The Cold Start Issue?"
Does it spit and sputter--but no cranky, when cold.
Just trying to distinguish fuel issue from spark issue....
The Medic
Aug 17, 2010 at 10:28 AM
RFORDVT
Thanks everyone, turned out to be a myriad of things. I adjusted the choke to get it seated properly while not operational. Next, I found a crack in a metallic vacuum line lead and sealed that with JB weld. Pulled all the plugs and they were all wet fouled from pouring gas down the carberator to start, replaced them, recharged the battery and it fired right up. Appreciate all the input.
Aug 19, 2010 at 3:05 AM
DOCFIXIT
  • 18,828 POSTS
Great news have fun tooling around in your Jeep
Aug 19, 2010 at 8:05 AM
