wont start
JOECOPAC
94 jeep cherokee straight 6.I tried starting my car and it didn't crank or make any noise attempting to crank just blank.I changed my relay switch under the hood and it turned right on.The next day it did the same thing,i tried changing the relay switch hoping the one i got was bad but that didnt work.I checked my battery it was good.Could it be my starter? :|
May 9, 2007 at 12:55 PM
SAMUELJE93
  • 14 POSTS
I realize this may sound kind of simple and probaly is not your problem But, try taking your battery cables off and cleaning the battery post as well as the cable ends. I have had this problem with so many different vehichles, and for me anyway, even tho the battery was good and the cables were tight, the corrosion kept them from getting good contact. I could turn the key, and nothing, as if it didn't even have a battery in it.
Jul 7, 2007 at 8:41 PM
