1998 Jeep Grand Cherokee Vent Hose
HITMANFORHIRE1
1998 jeep grand cherokee 110,000 miles I have a small hose that comes off the front transfer case and is now hanging down under the front of the motor it was never there before it looks like it maybe a vacum line can you tell me where the line is suppose to connect to any help would be appreciated thanks
Dec 10, 2006 at 2:22 AM
CARUNDELL
  • 602 POSTS
[quote:4ec7a7830b="hitmanforhire1"]1998 jeep grand cherokee 110,000 miles I have a small hose that comes off the front transfer case and is now hanging down under the front of the motor it was never there before it looks like it maybe a vacum line can you tell me where the line is suppose to connect to any help would be appreciated thanks[/quote:4ec7a7830b]
Hey hitman,
Sounds to me like it could be the x-fer case vent hose, I don't believe that year jeep had a vacuum controlled x-fer case.
Regards,
Chris
Dec 11, 2006 at 2:58 AM
Suggested Repair
Treat the hanging hose as the transfer case vent hose, not a vacuum line. This year Jeep likely does not have a vacuum-controlled transfer case, so do not connect the hose to a vacuum source; route and secure the vent hose so it is not hanging.
Conversation Summary
The owner of a 1998 Jeep Grand Cherokee found a small hose from the front of the transfer case hanging under the front of the engine and asked where it should connect. The expert said it is likely the transfer case vent hose and that this year did not have a vacuum-controlled transfer case.
