[quote:a2ad17f512="dipweed23"]Shocks are a fairly inexpensive part to replace IF you can do the work yourself.
I had a 1988 Cherokee that had the same issue. Hit a bump and it would bounce all over the place.
Since a mechanic checked the tightness of most of the undercarriage components, it's unlikely that your anti-sway bar is loose, or your springs arent seated correctly.
Inside shocks are little valves, and sometimes the full test of bouncing the vehicle up and down will seat the valve, but the vibration caused by a small bump isn't enough to make them seat.
I'd say to replace them first, and go from there.
Also have a mechanic check the CV joints, and axel shafts.[/quote:a2ad17f512]
Dipweed, thanks for reply. I was tending toward shocks but can bad shocks expalin the randomness of this occurrance? A few weeks ago I test drove the jeep (it had been my wife's) hitting every bump I could find and nothing. It does seem to be occurring more frequently.
Jul 23, 2007 at 6:07 AM
