Replacement Hose has no high side service port
JEEP CHEROKEE
COASTIEWITHJEEP
I have a 1995 Jeep Cherokee Sport, inline 6, with 150,000 miles. I am replacing the A/C condenser and accumulator and also need to replace the hoses due to rust. I just received replacement hoses in the mail and the condenser to compressor hose does not have a service port as the OEM hose does. Can I still install this hose? Do I need the high side port?
Jun 19, 2007 at 6:49 AM
MERLIN2021
  • 17,250 POSTS
To use gauges yes you need the port. To just charge system, no! but there may be a port on the compressor...
Jun 19, 2007 at 8:05 AM
COASTIEWITHJEEP
Wow, thanks for the quick reply, this is a great website you have. That makes sense, I'll have to check the compressor too but I'm fairly certain there's only the fitting on the hose. My concern is whether or not I "should" have a port in there, say if I later on wanted to have the system flushed or evacuated. I'm just a DIYer so I don't expect to be evacuating in the future on my own but someday I might wise up and bring it to a professional before getting in over my head. If I should have the port is it better to have a hose custom made with a fitting on it or should I be able to find a vendor that sells short lengths with a high side port in it (so I can just connect it between the compressor and hose)?
Jun 19, 2007 at 8:31 AM
