If a misfire in a specific cylinder should lead you to check the spark plug, fuel injector and compression
Here's more on misfires:
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
I thank-you for protecting our freedom-God bless you and keep you safe and keep your head down and eyes wide open
SPONSORED LINKS
Saturday, April 7th, 2007 AT 6:07 PM
