cooling fan not working
MATT25
I've checked this site and many others and cannot find an answer to my problem. My cooling fan will not run. I've checked the motor by wiring it to the battery - it runs fine. I've checked the fuses - they're fine. I've replaced the relay in the the main fuse box in the engine - it's fine. And I've even replaced the temp. sensor in the thermostat housing. Nothing seems to fix it. Although, when I first replaced the relay, the fan rand for a few minutes then stopped. I rechecked everything and it's all still good. Is there another relay or temp. sensor that I might be missing? Does the 2001 cherokee have a 2nd relay behind the headlight like the grands do?
The temp sensor in the thermo housing, it has two wires. Which one would I ground? If you're not talking about that one, where is the other one? I've read (haynes manual and other sources) that the temp sensor that controls the fan is in the engine block near the back left corner (closest to the driver). If it is there, I can't see it and would have a heck of a time replacing it because of the intake and exhaust manifolds. I will buy a retractable mirror and see if it's there, but I have been under and can't see any wires leading to that area. I think this particular in-line six cylinder engine doesn't have one there, but I could be wrong. I just wanted to get more information before I go removing a bunch of other parts just to see.
I never let it go too long (gas and all), but as I mentioned in my last comment, the temp. Gauge will slowly rise above normal temp. At idle. This is a concern only if I get stuck in traffic on a hot day. The highest I let it get was around 210-220 degrees F. I know it's unlikely that it will fully overheat, but I'm certain that when the temperature gets too high, the electric fan should kick on to support the belt-fan. Why else would it be on there? In my limited experience, A/C has only caused electric fans to switch on sooner (because of the extra cooling required for the condenser), but I've never heard of one existing only for the A/C system. Either way, I was planning on getting the A/C fixed next. Perhaps that will solve the problem, but it seems unlikely given what I know at this point. I appreciate your help on this. Any idea about whether it could be the radiator fan relay control in the powertrain control module. I don't know exactly where that is, but I see it in this diagram, and I'm sure I could find it. I've heard of other folks having to get a $50 relay switch for their cooling fan on comparable jeep models, but the one I replaced was a $10 one. I don't know if that matters, but is there a 2nd relay?
It does have two fans. The air conditioning isn't working right now. It's not leaking because the pressure is still good (I tried adding some 134a and it didn't take any). The clutch on the compressor doesn't engage. I thought this was a separate problem and was going to deal with it later. I've heard that the electric fan should eventually kick on at idle (because the belt-driven fan is only adequate at 25 mph or greater). If I leave it at idle, the temp gauge does keep creeping up, so shouldn't the electric fan kick on?
Also, a diagram would be helpful (I couldn't find an accurate one anywhere). I went back and checked the 15 amp fuse in the kick panel (still good). I don't know what the problem is. If it were set to only run when the ac is on, wouldn't there be a limiter or switch for that? I don't see one in the diagram. Could it be the Radiator fan relay ctrl (powertrain control module in the left fender side shield)? That's the only thing I haven't checked and cleared. I didn't even know about it.
Any help will be appreciated.
Thanks
-M
Jul 21, 2009 at 6:28 PM
BUDDYCRAIGG
  • 2,262 POSTS
There is a radiator cooling fan relay that goes bad in these cars. Here is a guide and some radiator cooling fan wiring diagrams (below) so we can do some testing to find out what the problem is. the cooling fan relay is located at the front near the radiator on the right side.
Here is three guides that will help us get it fixed.
and
and
What is making you worried about your fan not coming on? is the engine overheating There are many cars that the electrical fan does not come on until the temp gets to 220 230 and some cars do have a completely separate fan that only comes on for the AC.
(Check out the diagrams below)
Please run some tests and get back to us.
Cheers
Jul 25, 2009 at 4:09 PM
MATT25
Then why did the electric fan run for 5 min immediately after I first changed the relay? It hasn't run since. That makes no sense, especially if the fan doesn't come on unless the A/C is on. Let me clarify, the 210-220 degrees, was according to the temp gauge, it was in the process of climbing slowly when I shut it off. Anyone can open the engine compartment on this jeep and feel that it's definitely running hotter than it should. I'm worried that this will, overtime, fatigue vital parts and cause problems down the road. And of course, a hot day and heavy traffic could be problematic. The fact that the fan ran the instant I put in the relay, shutoff after a few minutes, and hasn't run since should mean that something isn't working properly. I suspected that the new relay just burnt out, which is why I put in a third one, but the fan didn't run that time. So I replaced the fan motor because someone told me the fan motor can pull to much amperage causing the relay to go out. So I replaced the relay again and the system has been fine ever since.
Thanks for the help 2carpros! I love this site
Jul 26, 2009 at 2:48 AM
BIGDANO
2001 jeep cherokee, cooling fan will not come on replaced fuses,relay and sensor
May 29, 2017 at 8:57 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
Try jumping power directly to it to test the fan motor. If the motor is good, test the inputs to the relay.
MSLYNETTE
Engine Cooling problem
2001 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
my fan stop working causing my AC to stop blowing to
BMRFIXIT
  • 19,053 POSTS
check fuses and relay
check coolant fan motor
most common is fan module relay
JEEPSTER
The symptoms I am having:
- Electric cooling fan does not come on when idling in hot weather
- Temperature guage always at the same level when hot - just below halfway mark
- Fan sounds like it is working overtime when accelerating
I have changed the thermostat and checked the coolant, both are good.
I don't have problems with overheating but am concerned that the electric fan is not coming on and that it always sounds like it is in warm up mode (fan working very hard)
I tried running it with the RPM's high on a hot day to see if the fan woul d come on but it didn't and the temp guage would not budge. I checked the coolant shortly after but it was cool?!? the top rad hose is very hot but I could put my finger in the coolant afetr removing the rad cap
Anyone have any suggestions?
DEMEARSJR
  • 110 POSTS
Could be either the coolant sensor or the cooling fan switch
May 29, 2017 at 8:58 AM (Merged)
RYBACK007
The engine cooling fan dosen't run not even with the A/C on it is a 2003 Jeep grand cherokee 6 cyl
FISHERMAN
  • 937 POSTS
[quote:2b9ff87963="Ryback007"]The engine cooling fan dosen't run not even with the A/C on it is a 2003 Jeep grand cherokee 6 cyl[/quote:2b9ff87963]
Hello !!
Start checking the fuses if good check the fan relay..
If you find a blown fuse check for loose conn. or faulty fan motor..
let us know and good Luck!
SERGIE1047
1999 Jeep Cherokee 6 cyl Two Wheel Drive Automatic 78000 miles
My jeep fan cooling is not working but it is not overheating only smell something burn. I replaced the temperature sending switch and the cooling fan relay. Now my engine light is always on, try to disconnect the battery it work for few days and the engine light check is back again. Please tell me what to do before I go to the shop or the dealer. I want to fix this if I can do it by myself. I appreciate any help.. Thank you Sergie Hernandez
BLUELIGHTNIN6
  • 16,542 POSTS
could be faulty engine coolant temp sensor. since engine light is on, take to local auto part store and ask them to scan your vehicle for trouble codes. most auto part stores do this for free.
EDWARD.S
  • 166 POSTS
Hi, First Thing To Check Is The Fuse To the Cooling fan. If That is Good , See If the Cooling fan Comes On When You Put On the a/c .If It Does come On The Fan motor Is ok. There Is A fan module That goes bad In jeeps At the time, That Module Is a dealer Item. Only.That module Is Behind The right Front headlight,On the Fender well. Sometimes It Is better to Remove the Front Bumper To Get Access to it. There Is a test in the Snap On Modis Scanner For it. To Turn It off and on .
Hope This Helps you,
Good luck
Edward S.
RBILLUPS
2003 Jeep Cherokee 6 cyl Two Wheel Drive Automatic 100000 miles
Engine runs hot because radiator fan does not come on. Fan works when I wire it directly to the battery. Also the fuse is ok and I changed the temp senor. What is causing the fan not to come on?
INTERNETMECHANIC
  • 700 POSTS
Check for trouble codes. If you do it yourself, at the least, you need an obd2 code reader. Check the circuits at the fan relay.
MISTYTERRY
2002 Jeep Cherokee 6 cyl Two Wheel Drive Automatic 125455 miles
My Jeep is over heating because the fan is not coming on. What are some things I can check? Will a code reader tell me what is wrong?
BMRFIXIT
  • 19,053 POSTS
Code reader will help if you have check engine light
if you have check engine light on
try and cycle key on off on off on read codes in odometer area
most likely and common is coolant fan relay module under right side headlight and battery
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
DEFLEPCHICK69
2002 Jeep Grand Cherokee Sport 65,000 miles.Cooling fan will not work.We have checked the fuses and they are fine.Can you please help?
SKIPPYTCG
  • 8 POSTS
I feel your pain on this one. My 1999 jeep cherokee sport, 4.o l with 99k on it has the same problem. If you get an answer to this let me know.
DEFLEPCHICK69
We got mine fixed yesterday.It turned out to be the relay.We had to take off the front bumper and grill to get to it,but we did and it was the relay.Hope that helps.
DENOTS74
1990 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 236856 miles
i got a 1990 jeep cherokee and the electric cooling will not come on , but if put 12volts directly to fan if runs great can not find fuse or what ever feeds voltage to the fan
OBXAUTOMEDIC
  • 3,715 POSTS
[quote:06c0163795="denots74"]Engine Cooling problem
i got a 1990 jeep cherokee and the electric cooling will not come on , but if put 12volts directly to fan if runs great can not find fuse or what ever feeds voltage to the fan[/quote:06c0163795]
Check the relay it is located on the Left Fender Panel in Front of the Washer Bottle.
If that checks out then most likely its the Coolant Temp Sensor and is located at the top front of cylinder head.
DENOTS74
thankyou for your time and effort it is good to see that thre people in this country who will still help people when they need it have a great day
FLINGER
My wife has either a 2000 or a 2001 Jeep Grand Cherokee. The AC blows cold when at sustained high speeds but it blows hot at idle and the engine begins to overheat. I read about the cooling fan and I checked to see if it was running with the AC on, and it is not. I can spin it with my fingers so I know it isn't obstucted. It also has a rattle/jingle type of sound that I notice at slow speeds like in a parking lot. Does it sound like I need a new fan? Is that something I can do myself? I am fairly mechanical. Does it require special tools?
Aug 15, 2019 at 12:21 PM (Merged)
DPWD23
  • 136 POSTS
First check the connections to the fan. If you can rig up a set of jumper wires with alagator clips you can test the fan by touching the wires directly to your battery for a second or two, just make sure you don't have anything in the way of the fan. They can cut your finger off, or hurt you pretty bad if not careful.
If it works, check fuses.
If all that fails, report back, and we'll go from there.
POKERCHEF5
I have a 2000 Jeep Cherokee Grand Ltd. and my radiator fan does not spin. I check the relay and the cooper connection looks to be in one piece. The fan spins freely whwen I turn it. Do I need to replace the fan and if so what would be an estimate cost to replace/repair?
OBXAUTOMEDIC
  • 3,715 POSTS
Hello, How did you check the relay? I ask this next question because some people look up relay location and relays for a cherokee and not the grand cherokee. And they are different. Were was the relay located? Did you hot wire the fan directly to the battery? If so did it come on... If not then most likely you need a coolant fan motor... Here is a picture of the relay for a Grand Cherokee..
https://images.2carpros.com/forum/automotive_pictures/188069_coolantfanrelaychryslerdodge_4.jpg
This is the location of the relay....Behind bumper on passenger side
https://images.2carpros.com/forum/automotive_pictures/188069_01grndcherokeeradfanrelay_2.jpg
VNAPP
  • 6 POSTS
97 jeep cherokee country,6cly, 4.0L, 100000, cooling fan keeps cycling,runs for 5 second shuts off,waits about 20 sec, runs 5 sec then off, is this normal operation? Temp. indicates 195 deg. to 205
consistantly at idle.
Aug 15, 2019 at 12:22 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
[quote:d114560e25="vnapp"]97 jeep cherokee country,6cly, 4.0L, 100000, cooling fan keeps cycling,runs for 5 second shuts off,waits about 20 sec, runs 5 sec then off, is this normal operation? Temp. indicates 195 deg. to 205
consistantly at idle.[/quote:d114560e25]
is it running with the AC comp
watch the clutch on the AC comp. if its cycling on and off
it may be low on AC gas 134A
VNAPP
  • 6 POSTS
[quote:b0326bca59="BMRFIXIT"][quote:b0326bca59="vnapp"]97 jeep cherokee country,6cly, 4.0L, 100000, cooling fan keeps cycling,runs for 5 second shuts off,waits about 20 sec, runs 5 sec then off, is this normal operation? Temp. indicates 195 deg. to 205
consistantly at idle.[/quote:b0326bca59]
it may be low on AC gas 134A[/quote:b0326bca59]
the AC was off, I had the heater on. Should the fan on cycle be longer???
MERLIN2021
  • 17,250 POSTS
What really matters is what happens when you turn on the A/C? does the fan stay on? Right now it seems to be controlling the temperature well!
Fan should run with a/c on...other times it will cycle!
VNAPP
  • 6 POSTS
[quote="merlin2021"]What really matters is what happens when you turn on the A/C? does the fan stay on? Right now it seems to be controlling the temperature well!
Fan should run with a/c on...other times it will cycle![/quot
Just thought the fan was cycling too much on and off and only stayed on for 5 sec. , thought mayby some temp sensor was going or what ever controls the fan cycles. sounds like the fast on cycles may be normal???? what is normal ops for fan cycles with AC off?
BMRFIXIT
  • 19,053 POSTS
even so u have the heat on the AC COMP STILL CYCLE .S
CHECK THE CLUTCH ON THE FRONT OF THE COMP AND NOTICE IF ITS OPERATING WITH THE FAN
