1998 Jeep Grand Cherokee Overheat
Hey Tam,
Ouch ...... OK .....so its opinion time hmmmm not sure if I want in on this one ......ahhhhhh what the heck .... simplified:
1. Check Engine Light comes on, car goes in for diagnosis/repairs. theres a reason for the light and when it comes on there is a problem.
2. Car overheats once,stop, do not drive again till its properly repaired. Head gasket jobs are expensive!
3. Weekly fluid checks are a must and the owner is responsible for this. most folks just get in and drive till theres a problem, never pop the hood to check anything till its oil change time, if at all.
As to your case ..... it may simply be a case of a failed thermostat causing the overheat or not, we'll never know
Thats my opinion, I'm a big promoter of preventative maintenance and allot of times you avoid serious issues because of this. I'd better stop lest I get blasted by the forum .............sorry guys.
Chris
My pleasure! (sorry 'bout the rant LOL)
Chris
Suggested Repair
Do not keep driving an overheating vehicle. Have the cooling system diagnosed before further use, including coolant loss and a possible failed thermostat, and address any warning-light issue. Continued driving after overheating can lead to expensive damage such as a head gasket failure. Check fluids regularly and repair problems promptly.
Conversation Summary
The owner described a 1998 Jeep Grand Cherokee that showed a check-gauge warning, later overheated with no coolant in the overflow, was refilled after cooling, then rattled, stalled, and would not restart. The owner asked whether ignoring the warning and fluid checks, or continuing to drive it, caused the possible damage. The expert said warning lights indicate a real problem, an overheating car should not be driven again until repaired, and weekly fluid checks are the owner's responsibility. A failed thermostat was mentioned as one possible cause, but the exact cause could not be confirmed.
