Hood will not open?
1999 JEEP CHEROKEE
ANGELLOVE1982
Engine Mechanical problem
1999 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
It looks like the cable that should be connected to the latch of the hood is not connected and my hood now will not open. Can I open it another way and connect the cable back?
Nov 25, 2009 at 3:32 PM
  • 110,194 POSTS
In this case, I recommend taking it to a body shop. They have ways to open hoods after accidents. Chances are they will need to remove the grill to access the lock.
Nov 28, 2009 at 2:03 AM
JPMCLAUGHLIN
1991 jeep cherokee - can not open hood to access engine
Sep 30, 2020 at 3:14 PM (Merged)
JDL
  • 16,098 POSTS
The release mechanism inside the vehicle, is it a plastic handle that a wire attaches too? Is the handle broke or the wire? If the wire isn't broke, sometimes you use a pair of vice-grips to pull on the wire, to release hood. It may help to have helper standing at the end of hood, Pop hood with palm of hand, in area of release mechanism, at the same time you pull on the wire.
If all else fails, you may have to remove front grill, where applicable, to get at underhood release mechanism.
MATTFRED
My 1999 Jeep Grand Cherokee hood latch release is broken. I bought parts for a 1999 Jeep for a new Control Cable Assy. for my hood release (Jeep Cherokee 97-01 Hood Release Cable Assy., Crown Automotive Sales Co., Inc., Part No. 55235483AD). But I can't open the hood latch release. I have used a screwdriver and a coat hanger to unlock the hood, but I can't get it open. I need to use my Jeep with the hood release because I need to use antifreeze under the hood. My Jeep saids that it is low on antifreeze. Any ideas?
Thanks
Sep 30, 2020 at 3:15 PM (Merged)
JAMES W.
  • 2,394 POSTS
If you pull out the grill you should be able to get to the hood release unit. You may have to push a screwdriver up a long the stem to push the release back.
2CP-ARCHIVES
  • 4,540 POSTS
cable for hood release snapped. can't open hood. how do you open hood to replace cable.
Oct 2, 2020 at 9:57 AM (Merged)
JDL
  • 16,098 POSTS
Can you get at the wire cable? I've seen several hood release handles, where the plastic handle broke, but, the wire cable was still there. I used a pair of vice grips to grab the wire cable and pull.
If there is no wire cable to grab, maybe you can remove the front grille, see if you can reach the release mechanism to open the hood. I've seen universal hood release cables in the autostores, I thought they were over-priced.
